AVB
- 2:17 PM
- May 4, 2016
- Elora, TN
This is what I was referring to when I mention couplers and plugs CFM rates needs checking. All these along hose size and length has a great impact on your air tool's performance. Not only the standing pressure needs to within specs, it doesn't matter much volume or standing pressure you have if it can't get to the tool at the CFM that they need, they simply will not work. This is what was happening to my new Aircat 1150. I was very disappointed when I first got it but it dawn on me to check the working line pressure at the impact. This where I found that even I had 125 psi standing pressure it was dropping to 20 psi working at the impact. So I went to work on finding what the restrictions were. I was hoping not need to upgrade to 1/2 lines. The problem was those M style couplers and plugs, they didn't even have spec openings.If your compressor does not seem to blow good, is it getting up to pressure? Does raising the regulator pressure help it blow better? It won't blow very long at high pressure with a small tank.
Now that I switch V style there very little drop in pressure at the impact. Of course with a 25 gal tank I still run my compressor contentiously using some tools like my die grinders and blow guns but the Aircat just sips air as it don't take much more that a bump most times to loosen a bolt. I also am operating with about 125 ft of 3/8 air hose so I can get to the customer's equipment while they still in my driveway.
