Looking good!!Got the crankshaft installer tools finished for the flywheel side of the ms440 and ms660 to my friend likes doing things a little bit different than others but this is cool and will work great hoping to get the tap tomorrow to finish the pto side.View attachment 151602 View attachment 151603 View attachment 151604 View attachment 151605
Thank you. I can't wait to put them to work soon. LolLooking good!!
“Harmonic Balancers” don’t balance an engine in and of themselves unless that have extra weight on them. They balance “harmonics” which occur when the crankshaft slightly twists with each piston firing.Re: Chainsaw balance … it is less expensive to "over build" the saw than to try to correctly balance it. That is partly why they all have AV. Single cylinders are tough to balance.
Easiest to balance: Straight 6 or V-12, then V-8, V-6 and 4 generally need counter weights.
Little Merc is back for repairs, still has a small fuel leak, fitting all new fuel lines, replacing 2 more hose clamps and found another vac hose had small damage that I hadn't picked up the first time.
Got a fishing trip next week, got to get this sorted.
Those are top of the line on portable generators. I've got the 12500 at my house for outages. When the power goes out I'm the only house for miles with hot water lol.Just assembled my new generator. Came on sale for half price. Fired it up for a few mins. Will hopfully try it out more tomorrow after work.
Looks good bud,Got the crankshaft installer tools finished for the flywheel side of the ms440 and ms660 to my friend likes doing things a little bit different than others but this is cool and will work great hoping to get the tap tomorrow to finish the pto side.View attachment 151602 View attachment 151603 View attachment 151604 View attachment 151605
Thank you. We drilled a hole through all the threaded rods so all I have to do is sick a screw driver through it or a small long small bolt so I can hold it. But your way sounds good to. As for the use of the tools I've put cases together the hard way heat and freeze tired of that game and with these tools it will make thing simple but I do still plan on freezing the crankshafts just because I'm legally blind so the less I need to rush the better for me and the saw's that I work on I injoy working on them most of the time but when I get more than five people in a rush to get there saw's back it can be tuff tripping over stuff. LolLooks good bud,
what plans do you have for the tool future? ie saw models.
When your first making them, I would recommend a LH nut instead of a RH nut for the flywheel side.
95% of tools comes with RH nuts for both sides, but if you use LH nut on flywheel side you will torque so the bolt doesnt screw loose.
