Cr v3’s and the esr cageView attachment 206916View attachment 206917 View attachment 206918You can see the cr cage is offset a little on the inlet
Thank you sir, that is a wealth of good information.
Wonder if a boost bottle would do anything here. Probly not a saw that’s full throttle all the time.Ok the reed spacer, two theories on that, so it increases the crankcase volume and that will lower crank case compression and full the ports with less pressure and add in low end and not support top end power. 2 is with a good top end pipe and porting, the scavenging effect of the pipe will gain with more crankcase volume and the pipe will take advantage of the extra fuel and air in the crankcase. On the trx we often run a cylinder spacer plate with the long rod and old piston, the cylinder spacer can range from .160-.250 and that’s the cylinder volume at the base gasket, it isn’t something that’s crazy noticeable, just an FYI.
On the carb side of the reeds the shorter is generally ideal for response, I am not sure if there is and ideal size, the cr used a super short carb boot and the trx is longer, I run the cr. The only thing I can maybe see is less reed spit back with a little longer intact side, but I bet the short is better for throttle response and even peak, but may cases some tuning differences
Ya my experience with boost bottles are on twins, I noticed a better idle quality and 1-16 throttle difference, I haven’t tried it on a single. Theory wise it should help low end and reduce spit back, so that could be helpful is certain times, Like if you had a really small intake boot area or a really short air filter where the spit back could saturate the filter and caused an extreme rich condition, As a rule of thumb on reed valve motor, you need at least a minimum of 2 1/2 times your carb bell diameter to the back wall of your air filter and that’s a minimumWonder if a boost bottle would do anything here. Probly not a saw that’s full throttle all the time.
Yup, stores that atomized fuel. When you get back in the throttle it’s instant.Ya my experience with boost bottles are on twins, I noticed a better idle quality and 1-16 throttle difference, I haven’t tried it on a single. Theory wise it should help low end and reduce spit back, so that could be helpful is certain times, Like if you had a really small intake boot area or a really short air filter where the spit back could saturate the filter and caused an extreme rich condition, As a rule of thumb on reed valve motor, you need at least a minimum of 2 1/2 times your carb bell diameter to the back wall of your air filter and that’s a minimum
I would would say it’s a cr500 cylinder, more picks and I could probably tellHave a good VeteransDay / Remberance Day everyone.
Just showing the breathing capability differences of the little '82 YZ125 on the left between the '83 CR250 on the right.
Now the CR250 intake has basically gone unchanged up to 2001.
The YZ needs the intake bridges removed and it will breathe alot better.
Last picture is a 2001 CR250R "B" cylinder I found listed on Ebay.
Count the head stud holes...7.
I'm very puzzled because the only 7 stud CR250 heads I know of are my 1983 and the 1984 models.
Anyone know anything about this B cylinder?
View attachment 207194 View attachment 207195
Yes, measure your cylinder base stud spacing both directionsYes I think you're right they mistakenly advertised a CR500 cylinder, bore looks huge too.
Do you mean measure my '83 Cr250 cylinder base stud holes?
Got it down on paper with metric steel ruler , approximate by eye (I do have a good eye for center on the cylinderbase)Yes, measure your cylinder base stud spacing both directions
