- 7:30 AM
- Dec 4, 2015
- In a meeting
I read that, but I was under the impression that he was fighting some very low temperature issues, and the charr from the burned out area was probably causing issues with the stop switch. To me, the primer bulb is a little stiff on this one. I’ve got mine that I’m comparing it with, and this one is a little bit stiffer.If you’re still having running issues, Jasha has a routine that has worked for him a couple times.
https://opeforum.com/threads/need-help-500i-issues.26028/page-3#post-1415241
@TINYHULK
I can replace it,probably have to order it, or you can.
Regardless, this saw is running better and better with every heavy cut.
