Slotting ignition coils holes
RockiesRider
9:20 AM
CO.
Has anyone done any modification to the mounting holes on an ignition coil? Or does anyone know if it would effect the function of the coil adversely?
Shane¹
11:20 AM
Kentucky
You should be able to slot the coil no problem. You just have to hold the plates together when slotting them. I have slotted them a bunch for 272 coils on 7900 and 066 coil on 9000 you can even see I cut the whole back off this one.
RockiesRider
9:20 AM
CO.
Thanks man, I'm building a compressor and I'm trying to get this old Briggs running to push the dual piston head I have. It will make enough cfm to run a decent media blasting set up for prep when powder coating.
Shane¹
11:20 AM
Kentucky
What does the coil look like Briggs are usually really easy to find coils for?
RockiesRider
9:20 AM
CO.
Yeah but shipping time takes quite a while Where I live, and I have a spare coil off another motor that's dead. It's got the same radius for the flywheel the holes were just a little too close together
