thedude74
Bonafide & Stuff !!!
- 3:32 AM
- May 23, 2017
- Alaska
That's a good point. Completely makes sense. I'm currently at 65% ex port/ cylinder width. But that's cut out of cardboard and held tight to the curvature of the cylinder....so probably closer to 60% actual width....Goal is a true 65% width.It depends how you port it too. A bigger/more aggressive exhaust port will allow less blowdown and more transfer timing. A more lazy exhaust port will require more blowdown. Muffler mod size will have some say-so in this too.
Haha was curious how far you hogged those out.I found daylight a few times on mine. It happens when taking it to the max. I have a curved caliper for measuring port wall thickness and I was flirting with the zero mark.
I was aiming for all-out flow. The flocked air filter can't flow enough air for it.Haha was curious how far you hogged those out.
It definately runs! What filter are you running on yours? Also, been meaning to ask you if your running the stock carb or a zama el42? Or other??I was aiming for all-out flow. The flocked air filter can't flow enough air for it.
I am currently using a flocked filter because the filter I got from hlsupply leaked fines into the intake and marred up the intake side of the piston/cylinder. You can see the damage in the picture I posted earlier. I am going to get an oem 44 micron mesh filter, and to hell with price. I'm done with the chicom ripoffs and low quality imitations.It definately runs! What filter are you running on yours? Also, been meaning to ask you if your running the stock carb or a zama el42? Or other??
I do see the marring now. That sucks. Good to know. I'll avoid the cheap mesh filters and keep an eye out for an oem part. North of 16,000? Damn! That's screaming alright! Doesn't sound like these have a limited coil.I am currently using a flocked filter because the filter I got from hlsupply leaked fines into the intake and marred up the intake side of the piston/cylinder. You can see the damage in the picture I posted earlier. I am going to get an oem 44 micron mesh filter, and to hell with price. I'm done with the chicom ripoffs and low quality imitations.
I am running the stock carb, or what I assume is the stock carb. It was on the saw when I got it. The saw would absolutely scream with the mesh filter on it, well north of 16k, and it was enough to make me nervous
