toolmaker
- 4:54 AM
- Jan 31, 2020
- Tyrone, Pa
Very nice fabrication there sir. Are you double nutting or roll pin staking the nut? I'm sure you are well aware but as that oscillates it will try and back off the nut.I have a home built log arch that I mess around with on weekends. Lost it a couple times, flipped itover more than a couple times.
Decided I need an offroad hitch that can articulate.
Here's what I came up with:
View attachment 330624 View attachment 330626
I will use a nyloc nut for final assembly and install a steel pin behind the nut for a little insuranceVery nice fabrication there sir. Are you double nutting or roll pin staking the nut? I'm sure you are well aware but as that oscillates it will try and back off the nut.
I have destroyed 3 ball hitch couplers so far.Ball hitch works well on mine, but I'm on pretty level ground.
There is a pic above. I also have a video, will try to post it.What are you pulling it with?
