mitos
Active OPE Member
- 7:51 PM
- Mar 29, 2020
- Slovenia
Hello everybody.
I want to replace the spur sprocket with a rim sprocket on my Husqvarna 61, grey top, production year 1988.
My intention was to use the Oregon Powermate sprocket, but the problems is that there are two versions. 102469 for the models with serial number before 0510572 and 26831 for the models after that serial. Since my saw was made in Yugoslavia and its serial number is 289625, I cannot select it based on the serial number.
Looking the picture of both Oregon sprockets the only visible difference is the 102469 (older) version has the needle cage bearing with a metal cage pressed fit in the sprocket and the 26831 (new) version has a loose needle cage bearing without the metal cage.
My chainsaw crankshaft has a fine thread and the spur sprocket has a the needle cage bearing with the metal cage pressed in it. Based on this, the logical assumption would be the right sprocket is the 102469 version, but I'm not sure. Searching on the web I have not found any decisive information that would help me decide which one to choose, the only thing that I discovered and might be decisive is that the older 61 had the coarse thread crankshafts and the newer the fine thread.
Does anybody have any clue which one would be the right one.
