You can use any line that will have a good seal and fit. I like using the black small echo line for the fuel line then a Poly ( yellow-blue) line for return just so one can see the purge is pulling fuel.
how easily does the drive shaft slide out?
i hooked up the attachment now that i got it running good. but it don’t spin…. took it back apart and it looks like something is missing in the drive shaft.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
