- 6:55 PM
- Jan 21, 2016
- Missouri
Who has an Economy Tractor, Power King, or Jim Dandy?
Does it still work around the yard?
How long have you had it?
And good stories behind it? Ill Start.
I own a 1961 Economy Tractor that I completely rebuilt in 2006. Every bearing, seal, worn part was replaced. stripped, painted and set out to get scratched and dirty again! My tractor was originally purchased for grounds keeping of a golf course near Baltimore, MD. My Grandpa purchased it from the golf course in 1963 and has used/owned it until 2006. in 2006 after his passing I acquired it and did his tractor justice by a complete rebuild. I use it to mow grass, haul things around in the cart, anything you would use a small tractor to do.
Anyone that is not familiar with these tractors here are a few bullet points.
Built from 1946-1984
All Gear drive
Engines
Briggs 23 10hp
Wisconsin AENL 9.2hp
Kohler
k241
k301
k321
k331
k341
k361
Borg-Warner 6" Dry disc clutch
Borg-Warner t-92 3 speed trans
Optional dual transmissions to give 9 forward and 3 reverse gears.
Ford Model A 4.11 rear end till sometime in 1962
Dana-Spicer 5.17 or optional 12.25 in JD from 1963+
They have many attachments available from mowing decks to tillers, front end loaders and so on.
here is mine.
My Dad in 1968
All Gear drive
Engines
Briggs 23 10hp
Kohler
k241
k301
k321
k331
k341
k361
here is mine.
My Dad in 1968
