- 8:27 PM
- Jan 28, 2016
- Dike, Iowa
old 040 - I peaked in the tank at the oil line...not good.
I scraped as much out as I could, a couple of rinses with acetone and the tank was surprisingly clean inside. I could see the nipple for the oil line, and an inspection inside the tank using my bore scope confirmed it was probably acceptable. I was able to insert a wire through the tank opening into the nipple and used that to guide a piece of 3/16" Tygon onto the nipple. By twisting and pushing (with the wire supporting it in the center) I was able to push the line onto the nipple quite securely. Since my only strainers that would fit through the small tank opening have a small nipple, I made a Tygon "bushing" from a piece of 1/8x1/4 tubing and pressed it into the end of the oil line, then inserted the strainer. It took some effort to get the line and strainer down in the bottom of the tank, but in the end...
I had another photo of the saw running on the bench with oil pumping out the bar pad, but alas I seemed to have lost it.
The 40V is now operational except for the fuel cap gasket and duckbill valve, those parts should be arriving sometime soon. I also ordered a new clutch drum as the sprocket on the saw was badly worn.
Mark
Mark
