Carb rebuild kits for Stihl and Husky Saws
jmester
3:40 PM
MD
RB-45 zama kit for your 55
K20-WAT walbro kit for your 55
K22-HDA walbro kit for your 254,257,262
RK-23HS tillotson kit for your 272/288/2100
K10-HD walbro kit for your 365/371/372
RB-60 zama kit for your 365 with zama C3M-EL2/8
K10-RWJ walbro kit for your 372XT
RB-163 zama kit for your 357/359 with C3-EL42
K24-HDA walbro kit for your 357/359 with HDA-199 carb
RK-32HS tillotson kit for your 385/390/395
K15-WJ walbro kit for your 385/390/395
K10-WJ walbro kit for your 394
K12-WG walbro kit for your 3120
RB-122 zama kit for your 340/345/346/350/353
RB-108 Zama kit fits your 334/335/338 with a C1Q-EL19 with remote primer
RB-109 Zama kit fits your 335/339 with a C1Q-EL20 with primer on the carb
RB-137 Zama kit fits your 338 with C1Q-EL33
K20-WAT Walbro kit fits your 335/338
jmester
3:40 PM
MD
RB-31 Zama kit for your 034/036
K10-HD walbro for your 046/460/044/440/361/029/039/310/390/ 461
K10-WJ or K15-WJ walbro for your 064/066/650/660/056 with wj carb
K20-WAT walbro for 021/023/025/024/026/260 unless it a wte carb
RB-105 zama for your 210/230/250
RB-36 zama for your early 044
RK-23HS tillotson for your 040/041/050/051/075
RK-1HT tillotson for your 084
RK-28HS tillotson for your 088/880 HT-12E
K10-WS walbro for your 042/048/050/051/075/076
RK-33HK tillotson for your 038
RK-20HS tillotson for your 056
These are walbro/zama/tillotson numbers if you want the stihl numbers I can post them as well.
K10-WAT walbro fits early 024/026 with WT-22 carb and 028 with WT-16 carb
RK-14HU tillotson fit 028 with HU-40 carb
RB-69 zama fits 200t/192t
K10-WTE fits 260 with WTE carb
My 260 pro has a wte carb on it the k10-wat kit is real close to the same kit. If I remember right the only difference is some impulse passage hole in the gaskets. Could be mistaken though has been a while since I was in the saw.
RB-176 Zama kit for your 261/271/291 Stihl part# 7010 871 0202
RB-185 Zama kit for your 201/201T. Stihl part# 7010 871 0227
The above two are not listed threw zama they are oem only. The stihl part number is list beside them.
berrnard
3:40 PM
southern, IN
anyone know the kit for 1116 120 0600 ?
carb on a stihl 015
and can this tread be stickied?
AVB
2:40 PM
Elora, TN
jmester, If you can convert the Zama kit to Stihl part numbers I can send you a list of Zama RB kits that I need the Stihl pn for. About 30+ different kits.
Also those that is interested Zama is no longer allowed by Stihl to sell these kits through the distributors and the kits must be purchased through the local Stihl dealer which in my case they can not convert the Zama kit number to Stihl or at least they are claiming they can't.
jmester
3:40 PM
MD
carb on a stihl 015
Walbro HDC-17
Carb kit # K10-HDC walbro
0000 007 1067 Stihl
jmester
3:40 PM
MD
I can try send some alongside and I will see what I can do. Carb numbers or model numbers will be helpful.
jmester
3:40 PM
MD
Dolmar 9000/9010 Tillotson HS-294/295 kit # RK-34HS
Stihl MS 880 with Walbro carb WG12/13 kit # K12-WG
Stihl MS 661 Walbro WJ-134 kit # K1-WJ walbro# 7010 871 0256 - Stihl #
Stihl 090 Tillotson HS-324 kit #RK-94HL Tillotson# 0000 007 1055 Stihl#
Stihl 070-090 Zama LB-S9 kit # RB-42 Zama# 0000 007 1084 Stihl#
Echo CS-750EVL Walbro SDC-70A
Walbro kit #K10-SDC
jmester
3:40 PM
MD
Husqvarna 562 Zama C1M-EL44/46 kit # RB-181 Zama# 522518901 Husky#
Husqvarna 550 Walbro AT-1 kit# K1-AT Walbro# 577666101 Husky#
Husqvarna 550 Walbro AT-12 kit# 582366201 Husky# No kit listed on Walbro
jmester
3:40 PM
MD
Zama Carb kit# to Stihl Carb kit part#
RB-11 - 0000 007 1082 - C1S 009-012
RB-13 - 0000 007 1083
RB-31 - 0000 007 1079 - C3A 034/036
RB-36 - 0000 007 1080 - C3M 044/440
RB-40 - 0000 007 1078
RB-41 - 0000 007 1081
RB-42 - 0000 007 1084 - LB 070/090
RB-66 - 0000 007 1085
RB-69 - 0000 007 1093 - C1Q 200T
RB-77 - 0000 007 1086
RB-79 - 0000 007 1088
RB-84 - 0000 007 1094
RB-85 - 0000 007 1089
RB-89- 0000 007 1091
RB-91- 0000 007 1093
RB-97 - 0000 007 1041
RB-99 - 4229 007 1060 - GASKET KIT
RB-100 - 0000 007 1039
RB- 105 - 0000 007 1040
RB- 106- 4314 007 1052 - GASKET KIT
RB-114 - 0000 007 1041
RB-132/134- 4180 007 1061 - GASKET KIT
RB-150- 7010 871 0229
RB-155 - 7010 871 0205 - C1M
RB-160/165 - 0000 007 1041 - REPAIR KIT - 4180 007 1060 - GASKET KIT
RB-161 - 7010 871 0222
RB-162- 4180 007 1061 - GASKET KIT
RB-164 - 7010 871 0206
RB-180- 7010 871 0247 - REPAIR KIT - 4140 007 1061 - GASKET KIT
RB-185 - 7010 871 0227 - 201T
jmester
3:40 PM
MD
That was all that I could figure out off the list that you posted above. I know that some of the kits are the same, I went back and double checked my work and came up with the same.
AVB
2:40 PM
Elora, TN
That will get a good chunk of them cloned for cross referencing here on my accounting system.
Just wished Stihl wasn't being such an A about the Zama stuff since they own Zama. Just makes things harder to do even for the Stihl dealers. I am finding work arounds on many of the kits. The few kits that I have priced at the local are nearly 3x what I was getting them through the Zama distributor. Stihl just wants a premium for them.
BTW the RB 155 and 164 are interchangeable as long you don't need every part. And yes many of the Zama are near duplicates which is why I have alternates list on my system here.
jmester
3:40 PM
MD
That is what I was thinking as well with the kits. Some of those kits I am not that familiar with as I don't do much work on blowers and trimmers. Just wanted to make a note so others would no to make sure they check what they take off there carb and what come in the kit to make sure it is correct. Glad I could help you out. Please feel free to add other kits that you know or figure out.
AVB
2:40 PM
Elora, TN
I am sending you an extract from the 2015 Accessory catalog that covers all the original carbs that Stihl had on the their equipment. But since many times they have sold replacement carburetors that used different kits so as you said double check what is on the Stihl equipment before ordering kits. This extract is before Stihl proprietary the Zama kits so that why I was and am needing the new 11 digit PNs.
jmester
3:40 PM
MD
Updated the list a little bit
Simondo
8:40 PM
UK
Just to add to the info......Dolmar Ps-5105 ..5100..500 ..Etc.... with Zama C1Q DM carbs 13...20 ..Etc
RB-119 works fine if you are not changing out the carb for a new one. UK costs are high so re build is my more common situation.
6400-7900 RB-101
5105 buy a carb
4300 buy a carb
6100 RB-235
Disciple of Monkey's
2:40 PM
For Zama carburetors, the prefix RB is for a full ReBuild kit and the prefix GND is for a Gasket aNd Diaphragm kit only. the numbers that follow do not match.
For example: for a Stihl 044 with a C3M carburetor the rebuild kit is; RB-36 and the gasket and diaphragm kit is; GND-25 .
Walbro uses the prefix of K for rebuild Kit and D for a diaphragm kit the rest of the numbers and letters that follow stay the same just the prefix is different.
Tillotson has the prefis RK for Rebuild Kit and DG for Diaphragm Gasket only. The number that follows differs as well with the carburetor family designation the only thing staying the same between the two such as; HS.
Hope this helps folks when looking for kits
