Nutball
- 4:20 AM
- Oct 31, 2018
- Mt. Juliet, TN
Comes with 20" bar, 2 square filed race chains, 8t rim, and tuned pipe. 32" Sugi bar not included. $1100 I might consider trades.
I'm sure this would easily run a 10 pin rim cant racing even without the pipe. The video shows it running an aggressive 20" full skip round filed firewood chain with 8t rim in Ash hard wood. Then running a new out of the box Stihl square skip 32" in Oak, but I'm beginning to realize stock Stihl square chain sucks like it's dull or something, but it sank through the log at a good speed leaning on it hard.
Video:
https://img.masterblasterhome.com/data/video/107/107904-5591cb90facc2882539798c328d34f44.mp4
Quirks: the choke tab needs to be removed after starting and stowed in your pocket or vibration will close the choke at high rpm. It is pretty easy to remove and install. Also it may start out with a fast idle when cold, but slows down a lot as it gets used. I haven't tried to make it really 4 stroke, but I think based on the porting if you try to tune it with reference to a 4 stroke sound, you will be way off.
More pictures to come.
Video:
