What is the best way to clean a file
Bjorn
7:48 AM
Sweden
How are you cleaning your files the best and easy way? I use file card and brakeclean and compressed air. But I need some more tips and trix. Especially Square files because they are exspensiv. Regards Bjorn
4:48 PM
Cotton cloth and/or leader glove.
peak-industry
leading manufacture for Saw Chain & Guide Bar
10:48 PM
China
try steel wire brush
Philbert
Chainsaw Enthusiast
9:48 AM
East Dakota
White vinegar
I heard similar claims about files and phosphoric acid many years ago (vinegar is acetic acid).
The idea is that the acid eats away at the flat parts of the teeth, crating a new, sharp edge. But why would the acid attack only the large, flat areas of the teeth, and not the fine corners / edges, which are surrounded on all sides? Why would it not attack the thinnest, most vulnerable parts first, dulling the fine edges?
Skeptical, I tried this once, and did not get any noticeable results. The biggest improvement was simply from cleaning the teeth. If vinegar, or the preparation mentioned in the video, help with that, that may be the only benefit.
I use a file card or stiff brush to clean my files. Files are a consumable, like sandpaper. Treat them well (e.g. don't let them bang around against other things in your toolbox or on the workbench), and replace them when dull.
Philbert
CR888
12:48 AM
Australia
I've heard all the file tricks too but they are simple consumables that get tossed. Good technique, a few taps & a few cleans with a large toothbrush is all I do. Trying to re-sharpen with acid might be OK for bigger files that are more expensive but I ain't mucking round with that, some find it hard accepting when a file is done but your best off trashing a saw file grabbing a fresh one & getting on with life.
redlinefever
9:48 AM
Iowa
Machinist friend showed me a trick years ago! Take a piece of copper pipe flatten it with a hammer then use said piece of copper to push all the crap out of the teeth works real good better than any file card will
Wonkydonkey
Plastic member
3:48 PM
Sussex, UK.
Sorry, but how does that work :confundio1:
redlinefever
9:48 AM
Iowa
I’ll post a pic when I head out to the shop of ease of explanation
Xr650jkallen
9:48 AM
Tennessee
I have coated a few in hot glue. Once the glue hardens up, you pull it off and it takes the shavings with it.
Wonkydonkey
Plastic member
3:48 PM
Sussex, UK.
I can see round files being a bit slow and more difficult with the flat copper pipe ;)
But can see how it works on a flat raker file now :)
Bjorn
7:48 AM
Sweden
If you make the tube flat and drill a hole so the file fit You can use it for roundfiles too
