ChipsFlyin
OPE Platinum Member
- 5:42 AM
- May 5, 2016
- Pittsburgh
I picked up a husky 261. The fast idle lock stop is broken off where it was supposed to hit. It's the white piece. See how you can accidentally push the choke lever too far making the lever go past parallel to the carb. If done so the bottom part of the lever slips off where it rides in the metal. When it does that it's stuck on throttle lock and choke.
Has anyone done a fix for this?
I'm thinking maybe pull apart , drill a micro hole and heat then insert a very tiny brad.
The part is basically NLA.
https://www.ereplacementparts.com/l...833428.html?osCsid=trf7da8loj28cd0k9jb78gkfq0
The piece is upside down in the part pick compared to the way it is on the saw.
Saw pic.
Saw pic.
