Mad Professor
- 2:45 AM
- Oct 21, 2020
- Northeast USA
Money is a little tight so floating the idea of selling off some of the saws I don't time to work on. I don't have current pictures of all of them. Some are at my other place, and the ones here are out in a freezing barn that I need to dig out from this weekends ice/snowstorm.
You can post or PM me if there is an interest in any of them and I'll try get pictures and some more details on the condition, maybe compression test. Might take a week or two depending on which saw(s) and where they are located. Some have bars but may cost more to ship.
Easiest way for me to ship is FedX. Prefer US postal MO.
Stihls
056
1) 056M well worn from a logger, and ran/started but has suspect bad coil, partially disassembled have to check if any parts missing?. Dies after a few minutes running. Piston has wear but no scoring. Need to get pictures.
2) 056M complete saw was told it ran by former owner, but oiler not working. Good cosmetics. Have not tried to run it or checked P/C. Need to get pictures.
3) 2 or 3 056? parts carcasses. Could part these out or sell whole. Good for parts only, missing parts on all. No pictures now.
046 Has broken handle. Turns free and P/C looks OK through muffler. Would have to check if P/C is OEM. Handle gas tank broken. Have a few pictures. Could part out. Have recoil assy
440 Similar to the 046 above. Have a few pictures. Need to check if P/C is OEM. Could part out.
Early 064, Bosch coil dogleg coil mounts. Have not tried to start it. Complete and P/C looks OK. Has upgraded HD air filter. Case has a crack around one of rear AV mounts but should be reparable, need pics of this one.
026
1) from farm auction. Complete have not tried to run it. Has 150psi compression, but piston shows some carbon on ex side. Might be a candidate for new piston or run as is. Have some pictures.
2) Complete good looking saw but looks to have been straight gassed or lean seized. A good candidate for piston or P/C if cylinder won't clean up. Need to get pictures.
Husky
257. Don't know much about this one, was given to me. Missing air filter parts. Pulls over and has compression, have not pulled the muffler to check P/C
Stihls
056
026
Husky
