Ugly Stihl 064 overhaul
redline4
I'm huge in Japan
8:48 PM
Rosholt Wisconsin
It seems my 064 decided to stop oiling the bar.
It still oils the bench, the shelf it sits on, the back of my truck or the bucket of my skidsteer from the case half gasket.
So, I've decided to give it a full tear down.
This will be in real time. It's deer season and im also working on an engine build for my car, so expect this to be like a trip to the Department of motor vehicles, slow, aggravating and totally unsatisfying.
I did order a gasket set, but now that I'm thinking, I did not order bearings...
Now, if you see me doing something wrong, let me know. Being a dumbasś is second nature for me.
So, without further ado, here it is.
20231112_103210.jpg20231112_103214.jpg20231112_103220.jpg20231112_103227.jpg20231112_103235.jpg
Ignore the HD2 filter stuff in the background. I returned it to the condition it was in when I got it for the purpose of this thread.
redline4
I'm huge in Japan
8:48 PM
Rosholt Wisconsin
Hold the throttle open with the trigger
Then hold the tab on the carb while releasing the throttle. That will allow the link to disconnect
Remove the handle screw, pop out the presence lever, spring and the trigger.20231112_103746.jpg20231112_104041.jpg
redline4
I'm huge in Japan
8:48 PM
Rosholt Wisconsin
Remove the 3 cover screws and the cover
And expose the nether regions not typically seen..
Well, that probably explains the lack of oil to the chain...20231112_105359.jpg20231112_105426.jpg
Tip it on its side to pour out the chainsaw seeds.
According to internet lore, if you plant these in the field they will sprout new chainsaws..20231112_105445.jpg
redline4
I'm huge in Japan
8:48 PM
Rosholt Wisconsin
Remove the 4 top handle screws
I apply the brake to take tension off the spring, then remove with vice grips.
Followed by the E clip
The handle/recoil screw
And with a twist, a turn, a little prying and a gfy, slide it off the studs with the brake link.
redline4
I'm huge in Japan
8:48 PM
Rosholt Wisconsin
Remove the remaining 3 recoil screws and lift it off
Not sure what the deal is with the mutant coil. I don't know much about these..
But, all the wiring is solid state..
So, pop off the wires in the carb box
Fish it through the grommets and pull the whole works out.
redline4
I'm huge in Japan
8:48 PM
Rosholt Wisconsin
I removed the upper mount
Followed by the jug to case screws
And pull that mutha off.
And here's the piston..
And that's where it currently sits as I'm going to get ready to climb a tree and see what the deer are doing.
jacob j.
Only the weird
6:48 PM
Coastal Oregon
Hey Ed - If you have the older style clutch that uses the "winged" shoe retainers, then that style does not use the clutch washer.
That looks like an early 064 for sure, so this is going to be a great build.
redline4
I'm huge in Japan
8:48 PM
Rosholt Wisconsin
Thanks JJ.
I'll flip it over and get a pic next time I'm out there.
I do believe it may have the clutch you are talking about.
9:48 PM
