- 8:46 PM
- Dec 26, 2015
- The land of pleasant living
I finally got tired of working on my chainsaws in a cold garage. My little propane heater did little to take out the chill. So I bought a torpedo heater, 135,000 btu, and brought it home. The dude said he bought another one and this one had sat for about a year. Said he has trouble firing it up when its lie, but it does fine with fuel. Brought it home, filled it up and alot of smoke pouring out of the tube. Hmmmm..
Swing the cover off and she fires up. Ok....I know about chainsaws but shat about torpedo heaters. Youtube here I come....found out the vanes in the airpump are usually a culprit...took it apart..sure enough the vanes werent dropping like they should. Took it apart cleaned it up, and got the vanes to drop like they should.
Took the nozzle apart and sprayed with brake cleaner, spark plug regapped and checked the lines. Fired right up. Good..... proud of myself. Got a new air filter kit and installed. Now it wont fire up unless the top cover is removed. WTF!!! Went over that machine again so I could take it apart in the dark. Then I got thinkin....the replacement filter gasket looked thicker than the original. Didnt throw away the original, wife would shudder at that thought, and replaced the new with original. Fired right up. Hmmm..didnt think that would make a difference but it did. For something so simple it is touchy to the least little change...
