FOUND IT Tillotson 296a
Josh0619
6:38 AM
Bagley mn
Looking for a carb for a 390xp, would like to stick with a Tillotson as I just bought a carb kit for mine but the low speed passage is plugged. Tia
hacskaroly
4:38 AM
Northern Idaho
Sloughfoot
4:38 AM
Norcal
You may have already done this. Blow it out with carb cleaner from where the fuel enters the passage under the metering diaphragm? Should be able to see it come out inside the venturi. Also, some carbs supplement low idle through the high speed jet. Welders tip cleaning kits are great for cleaning those tiny passages as well.
ManiacalMark
7:38 AM
PA
I have a brand new 295 but I’m not sure they interchange.
Josh0619
6:38 AM
Bagley mn
I’ve pulled the Welch plug and can not get anything to fit in that tiny hole. Short of an ultrasonic bath I’ve tried everything and it will not open up.
