Mr_Leffe
OPE Member
- 1:21 AM
- May 25, 2020
- Corralitos Ca.
Hello All. I have an old Super Tomahawk. Serial # W826516. Model # is unreadable.
The original B/S 8 HP lost compression on a cold and Winter morning so I replaced it with a 321cc Predator.
Has been running fine but has started to make loud shrieking noises from the business end.
I don't think it is the belt as the belt is a tad too small and is constantly turning the blades but the idler needs to be engaged to cut.
Makes the same noise ticking over or full bore. I fear it's the outside bearing, could be both.
Have found some bearings @ Chalmers but we need the model # to pull the trigger on a sale. Could use some help identifying my beast.
Could also use some help with a procedure changing out both bearings. Do I have to take the engine off again to do this?
How large of a chore is it to change the Flails?
Thanks.. Steve.
Thanks.. Steve.
