jakeshi
- 6:20 PM
- Feb 2, 2019
- Richmond, VA
Our saws were made during the same week!
@pbillyi69Mine's way rougher than those but similar age.View attachment 286547 View attachment 286548 View attachment 286549
Can you please explain what you are referring to??? Sounds very interestingI wonder if anyone on this site has owned and operated that version of the 262 that had a little led bulb in the rear handle and a computer?
Looking at the pic, and im only assuming here, but those bolts look more like screws for the heat shield. I bet that behind that shield are the standard muffler boltsWhen did they switch from the 4 muffler bolts? I assume to 2...
That early version of the 262 had a computer box in the bottom of the rear handle, hence that storage compartment. The little cutout area housed an LED kinda like the red light 066. All it did was light up when a certain rpm was being recorded so it helped you tune the saw easier.Can you please explain what you are referring to??? Sounds very interesting
How’s it run?I have one on a '91 saw, with an hda 87, only one I've run across.
Stock running saw, haven't yet had it apart to check timing numbers.
