I have straightened a couple using an end vise on my woodworkers bench and a lot of trial an error. A few were impossible. The angles are almost impossible to duplicate and match the originals. In addition to bend, you will also run into twist. Also, when the bar bends that much, the case is usually also in bad shape. And, when that happens, a new bar won't even fit right. Good luck!
