SOLD Stihl MS460
DELETED (Struggle)
1:07 PM
iowa
What you see is what it is. I bought it a while back and never did anything with it. I put fuel in it and thought it wasn’t getting spark and it is sparking and will run for a bit then it won’t restart. First round last night I put it in the truck to run next day and when I pulled it out of truck it was hydro locked with fuel. Took carb apart and metering lever was set high above carb body reset lever and then was able to get it to run made a couple cuts and then it fizzles out like coil doesn’t have spark, but does when plug is removed.
Anyways pulls 120PSI hot after it was running. I’m selling it as parts as I’ve never run it more than three cuts. Recoil rope is one pull away from breaking. Recoil has break in it as well as air box cover. I had recoil off and there was no play in bearings. It needs a strong going over.
Figure 20 lbs for shipping.
PayPal prefer F&F but if you are not comfortable with that then you can pay the extra for G&S payment.
Ships from Iowa
$350+ shipping
DELETED (Struggle)
1:07 PM
iowa
Sorry it has been sold. I thought I changed it to sold
