Stihl MS400 CFB style
Canadian farm boy
“Normal” people scare me.
8:41 AM
Ontario, Canada
The sides of the cylinder extension are flat so after cutting the base you have a small ridge left on each side that has to removed. I don’t have any fancy way doing that so I just carefully go at it with a file until the ridge is completely removed. I confirm this with a straight edge. You’ll also need to remove some material from corners of the exhaust side to allow the cylinder to sit down properly on the cases
Canadian farm boy
8:41 AM
Ontario, Canada
I like to keep the muffler mod simple on these newer stihl saws. I cut away most of the stock outlet deflector. I open the stock outlet up to about the same size as the spark screen. I then bend up my own defector much larger than the stock one and weld it on overtop the remaining stock deflector. I replaced the factory spark screen with a much much more open screen.
farminkarman
I like the red & black ones
7:41 AM
Neenah Wisconsin
View attachment 454298View attachment 454299View attachment 454300View attachment 454301View attachment 454302
I like that mod…looks nicer than a second outlet.
Canadian farm boy
8:41 AM
Ontario, Canada
For the timing advance I simply put my degree wheel at TDC. I mark the tip of 1 FW fin with a sharpie and mark the case. I then turn the degree wheel 6 degrees and put another mark on the case to line up with the marked FW fin. Remove the FW. Then put the saw back to TDC. I file the FW key until with the piston at TDC the marked FW fin lines up with my 6 degree mark. I then install the FW and tighten the nut down using some recoil string as a piston stop.IMG_6040.jpegIMG_6041.jpegIMG_6042.jpeg
Canadian farm boy
8:41 AM
Ontario, Canada
I know someone is gonna be curious and everybody loves numbers so here’s where I set it
I 80
T 120/124
E 102 and widened to %65 of the bore
I find most all strato saws like a little shorter BD when compared to other saws.
I’m also a fan of keeping the muffler outlet as close to the cylinder as possible. It definitely helps with noise and I find it also helps to keep a wider power band.
