Stihl HS82 Service Manual
fascat
Active OPE Member
7:13 PM
Pennsylvania
I'm looking for a service manual for the Stihl HS82. I saw the thread stating that there was no service manual for the HS82 and should use the HS81 manual. Is that still the case or has a service manual been released for the HS82? Does anyone have a service manual for the HS82 or HS81 that they could share with me? I would appreciate it. Thanks in advance.
ray benson
6:13 PM
nw indiana
Can't send you a conversation with the manual. Check your profile, privacy, contact details - something isn't set right. Also is it a HS82r or HS82t?
ray benson
6:13 PM
nw indiana
Looks like you made changes to allow conversations.
Check your inbox, added you to a conversation that has the 82r and 82t service manuals in it.
fascat
Active OPE Member
7:13 PM
Pennsylvania
Thanks for the quick reply. I checked my profile and found that the "Start Conversation with you" was not checked. So hopefully that will fix the problem. The manual is for the HS82t. I look forward to hearing from you.
fascat
Active OPE Member
7:13 PM
Pennsylvania
Thanks Ray! I was able to download them. I really appreciate it. I saw the IPL for the HS82t and the service manual for the HS82r. I'm assuming the service manual for the HS82r would be the same for the HS82t.
ray benson
6:13 PM
nw indiana
There is a separate service manual for the 82t
ray benson
6:13 PM
nw indiana
Check your inbox , added the HS82t service manual. The ipl is for the 82R and 82T. But they have separate service manuals.
fascat
Active OPE Member
7:13 PM
Pennsylvania
Got the HS82t service manual as well. Thanks again. I really appreciate it.
Nito
OPE Member
1:13 AM
Spain
Hello, I'm looking for the manual for the same hs82 t. Can you send me too.
Thanks
Tobermory
Active OPE Member
12:13 AM
sussex
Hi Ray,
Would it be possible for you to send me the HS82t service manual too? Many thanks.
Tom hadlow
Active OPE Member
12:13 AM
Uk
Hi can I have a copy of the two manuals as well please
HAM1
OPE Member
5:13 PM
Idaho
Hello. I would very much appreciate the Service Manual for the HS 82 R, Please.
Spirit
Active OPE Member
1:13 AM
Belgium
Good morning, from belgium, I'm looking for the service manual for the HS82-R. Can you send me too.
Thanks a lot. Have a nice day.
