Redbull661
661 hoarder (BlueBallz)
- 12:51 AM
- Dec 31, 2015
- wisconsin
Letting one of my 661-R's go. Need to raise some cash for the oil test! Did some work on it with the help of Tree Monkey's guidance. :rock2:
- Gasket delete - Stihl Dirko used.
- modded the air filter cover
- got some heavy duty spikes for it.
- it does have newer in spec coil
- it does have the newer "straight" intake boot
- removed the baffle and opened up the muffler port some.
- Timing has been advanced as well .025 off key
- only ran on 32:1
- oh and I also painted the elbow on the R handle matte black instead of the white plastic.
...and it rips pretty good!
I can also drop it off with Tree Monkey for porting and save you some shipping around if you like. He's about an hour from me.
Here it is running and then cutting in hard wood with a 36" .404 full comp chain (stihl RS)
edit: $1050 shipped to lower 48
- only ran on 32:1
