landlubber
Hello,
I have a 261 carb saw that I purchased new. The saw has only run Stihl HD Ultra silver bottle at 45:1 or occasionally Stihl MotoMix at 50:1. I was bored and popped off the muffler and found this.
It looks like a piece of carbon has come loose and there is a mark through the lower ring, a groove in the piston and the chunk appears to be embedded between the rings in the piston. The cylinder, when inspected through the spark plug hole shows a corresponding mark that doesn't look like it has depth but the crosshatch is worn through.
This event has me switching oil and mix ratio and I've ordered a tach to tune the saw but I never suspected it of being overly rich. The saws compression is 160psi and the factory headspace looks to be about 0.038"
Options:
1 ) Change oil, mix ratio , tune and run it.
2) Teardown, inspect cyl and break glaze, new rings and buff out the piston
3) Sell it and buy an autotune 261
Thanks,
LB
Options:
Thanks,
LB
