That's what I'm short on. Have parts to build up several of these but short on wrap handles. I realize they can be had aftermarket but that eats up all the flipping $.
If the cylinder is OEM, it will say 029 46 on it if it's from the super. That's the same cylinder as used on the MS290. If it just says 029 on it, then it's the 45mm cylinder from the 029. The 039 and MS390 cylinders are marked 039.
