popopboat
- 5:45 PM
- Sep 17, 2019
- Croatia
Hello everyone,
few days ago i started working on a neighbours Stihl 08, hasnt been run for 15 years or so.
Firstly i replaced carb diaphragms, fuel and breather hose, oil seals and cleaned it from inside out.
It took only 5 pulls to start, and after idling for 3 seconds it shut itself off (like kill switch), then i pulled again and it only coughed few times...
Then i recalibrated ignition (breaker point system), pulled and pulled - only few coughs again... Left it as it is, and tomorrow it started flawlessly and actually RAN, so it fixed itself over night, right....
Anyway, after it started always flawlessly, BUT really stuttered when accelerated, exactly like spark is dissapearing or kill switch is engaging (but it had no switch, only open wire).
Recalibrated ignition, cleaned carb few times, no improvement at all.
Then i replaced sparkplug wire, condenser, and breaker point thing(yea) and it wouldnt start, so again i recalibrated ignition timing * few times and then just like that it started and began working flawlessly, acceleration was smooth, no cuts or stutters at all.
Then from all joy and happines i went for a few cuts, and bastard worked again flawlessly for literally 3 cuts, and on 4th cut it started to stutter again! But this time its less like spark problem and it gets worse as the saw heats up (but a serious air leak feels way different than this)
I spent too much time on this shiet, i literally dont know what else to do.
This is the first saw that im loosing my mind on.
Ive recalibrated ignition and recleaned the carb atleast 7 times!
Ive set the ignition as manual says (2.4mm before TDC, 0.4 breaker gap and 0.5mm sparkplug gap)
Carburetor is set on 1 turn out on both L and H, but it doest not really make a difference if i change it.
Heres a video
Sorry for probably a hard to read post.
EDIT: I know on this video it really seems like a carb problem, but sometimes its like that and sometimes it really feels that killswitch is engaging (which is not)
Heres a video
