- 11:27 AM
- Jun 5, 2016
- Northwoods of Wisconsin
When it came time to fire this saw up, it was blubbering rich and didn't care to run at one turn out, with the High speed adjustment all the way in it was still overly rich but would stay running was about all. Remembering that the Hi speed adjustment needle was damaged seemed to be a clue that the seat was also damaged and letting too much fuel in. These things are known to run rich, but this was ridiculous. In the 084 repair manual Stihl states there is a carburetor that has a fixed Hi speed, another with a semi fixed Hi speed and yet another one that is fully adjustable. What they don't tell you is which one is which. The are Tillitson models HT-1A, HT-2A and HT-7A. The original carburetor was a HT-2A and Alex purchased an HT-7A. Upon installing it, not knowing what to expect all I could do was try it. It came from the factory set at one turn out, this was encouraging. It ran good set up near like it came I only turned it a touch. With some 32:1 in the tank and a bit rich setting I did some cutting with it and was finally pleased. The video I had is gone, so you'll just have to go on my word as I sent back the big bar with .404" chain on it I borrowed to test it, as a fella I knew offered and seemed a better option than purchasing, as most likely I'll never need one again.
An interesting side note I had planned on running that bar on the 070 that I did at the time as well, it did not fit/work. While the mount is the same size, the holes for the adjuster tightener upper are in a different location. Some AM bars have both holes present to fit wither scenario. Stihl makes a different bar for each.
