- 12:08 PM
- Jun 5, 2016
- Northwoods of Wisconsin
Good question. If you'll take notice of the tool holder for my boring bar is an older style that needs to have the height set every time I use it. Since chainsaw cylinders almost always have a casting line running smack down the middle of them and my lathe has been leveled in with a .002" machinist level, I can plumb the exhaust port and set the casting line at 90 degrees and have a visual clue as to where the middle is and therefor center is to set the boring bar cutter to. It's just a faster way with less steps for setup.What are you checking with the level?
Now at some point here in the relatively near future, I will be updating this to a more modular quick change type tool holder that only needs to be set the one time and can therefore be implemented in an easier manor and eliminate this step.
Along with this new cutting bits and boring bars with changeable carbide tips will also be acquired to go along with. Having just recently broken my favorite lathe bit for cutting cylinder bases spurred this on and newer styles had to be ordered already setting this into motion, one set is already here and another on the way and more to purchase as I go along that I've already eyed up.
As a side note for anyone not understanding something in the series of pictures I've posted, please ask as it's not easy to explain every last thing along the way when trying to upload them from my phone, as I would just as soon type out words on my computer keyboard instead.
