Now it came time to pick a piston, which I had the freedom to do, even though as it went some cheerleading for the Wiseco. Which had the benefits of saving weight, fairly important in this particular scenario, the Wiseco is also forged and is a tougher piston, and with one only running one ring geared towards high performance. One other advantage was the window size of the Wiseco. The new improved Stihl piston had extra weight which will soak up more heat, two rings which will give a compression advantage especially as it wears over time. Unfortunately, a smaller window than the piston it replaced, which tells me they went for more beef in the redesign.
This being not only just a rebuild and a bit of restoration it also is supposed to perform better. I decided to try out the Wiseco, but first check it out, just in case a reversal was in the cards, not just now, but maybe down the road as well. Then, upon fitting the Wiseco, a big negative reared up its ugly head. The bosses between the upper connecting rod were quite wide, wide enough to let the bearing slide out one way or the other a fair amount. This I absolutely did not take a liking to, as it turns out after talking to
@Definitive Dave on the subject, this is as small a gap as can physically be had on the Wiseco forge. So, now the thinking begins, at first, going back with the OEM piston was a likely solution unless something could be done to correct the situation with the Wiseco...
View attachment 489709View attachment 489710View attachment 489711View attachment 489712
