Fruecrue
certified hand catcher
- 11:01 AM
- Jan 4, 2017
- Alden NY
Stihl 064
Bought with a broken case half and cracked tank handle. I sat on it for a while, found parts, here it is.
Runs, oils, idles, and cuts.
Wrap handle is beat up but solid, flag does not match the wrap. Brake is functional but takes a smack to the flag to reset.
Cases had a slight variance in deck height so a bit of motoseal was used with gasket.
Pressure and vac tested. Saw is tight.
PTO side bearing is AM. New CEKN Bearing was cleaned, inspected and ultimately used. No defieciencies were noticed, I’ll include a video of said bearing dry and lubricated outside of the saw before installation.
New Nachi bearing on flywheel side.
New OEM gasket and seals.
Piston and cylinder are in excellent condition, never scored, original OEM rings.
Airfilter Mount was broken and repaired with JB weld, pics will be included.
Some fasteners throughout are AM.
Muffler is a bit crushed in but cosmetic damage only.
Asking $425 PHO plus shipping.
