WANTED Stihl 056 magnum cylinder
Trader history (1)
Jake Dykstra
12:31 PM
NW Washington
Looking for a decent 56mm cylinder for a 056 that a friend is working on.
Thanks
Junk Meister
2:31 PM
Nebraska
Have several 54s but no 56s 🙁
To the OP and other readers
The 056 mm cylinders don't interchange with the 52/54mm cylinders.
If the serial # is 9 digits and starts 114 xxx xxx or higher that case will need a 56 mm cylinder ...
I am use to making mistakes but I am sure enough to stick my neck out on this post.
Stihlalltheway
2:31 PM
Minnesota
It can be done. I “machined” (read: angle grinder) a piston and drilled out the holes on a cylinder to make a 56mm p/c work on a 045 case. I wouldn’t recommend my way, but the saw does still run and it wasn’t the cleanest job of all time.
Junk Meister
2:31 PM
Nebraska
I have read of putting 066 cylinders on a Magnum case , I guess it comes down to the definition of interchange.
I can Identify with the right angle grinder.
