SELLING Stihl 051 powerhead
Carhartt
5:53 AM
Central Pa
STIHL 051 powerhead only. Runs well. Just making room on the shelf. It has a stripped crank thread that held the clutch washer on. I just drilled n pinned the crank to hold washer on and it works fine. I have another crank for it if buyer feels the need to change it out and wants to make an offer on it. .404 drive.
250.00 plus shipping for the saw only.
Carhartt
5:53 AM
Central Pa
1 more top pic
67L36Driver
4:53 AM
Pinned? As in roll (expansion) pin?
Carhartt
5:53 AM
Central Pa
Split pin or cotter. I can take a pic of it and add.
Carhartt
5:53 AM
Central Pa
A long roll pin might be a stronger choice.
67L36Driver
4:53 AM
Just had to look at the IPL. Outboard clutch.
Cotter pin should work OK.
Big washer keeps the clutch shoes from jumping ship.
Carhartt
5:53 AM
Central Pa
Exactly what it does. I wondered if a newer clutch with retainers would fit. Never took the time to measure and compare.
67L36Driver
4:53 AM
I had a small, old Echo (302?) that someone brazed the washer on.
Fired it up and used a file to ‘turn’ it down. Put on the new spur drum and use a small set collar.
Carhartt
5:53 AM
Central Pa
Pic of the drill n pin to keep washer on since the threads where destroyed.
