Sawyer94
- 1:47 AM
- Dec 8, 2017
- California
Selling 051 parts. There were no badges so I am going off part numbers here. I will try to include all the part numbers and pictures I can. I am sure someone somewhere needs em.
Cases with flywheel and clutch assembly. P/N: 1111 020 2910
(Crank spins freely, clutch and flywheel whole)
Full wrap handle bar.
Handle assembly.
(Trigger, trigger stop, and operator presence lever)
Handle frame.
P/N: 1111 084 0900
Gas tank and starter assembly.
(does not leak and starter assembly minus pull cord)
Muffler
(Need to be opened up rust inside)
Ignition coil, made in germany
P/N: 2 204 222 022
(Damaged but possibly repairable needs rewiring)
Air filter base housing.
P/N: 1111 141 0801
(With on off switch and choke lever intact)
HS60B Tillotson carburetor and intake manifold.
KS laPiston And cylinder
(Both scored and cylinder plating chipping)
Miscellaneous parts
(Nuts and bolts, heat shield, and falling spike.)
I have no price in mind if you are interested send me a PM and we can work something out. This is going to be a flood of pictures but I didn't want to leave out any detail. Thanks for looking.
Brock.
Handle assembly.
Handle frame.
P/N: 1111 084 0900
Muffler
P/N: 2 204 222 022
P/N: 1111 141 0801
Miscellaneous parts
Brock.
