ursinykb24
I have a stihl 045 here I have both styles of starter cover types two carborators both 50mm and 54mm set up just got a new rebuild kit for the older nasty carb. Have a new 54mm piston kit on the way should be here Monday or so if it gets here after trade I'll ship it separately and I'll pay for the shipping on it two styles of muffler the older style muffler needs the bottom holding bracket tack welded back on or single bed weld should be good I can't currently welder is out for the count. Has 404 spur sproket on it full wrap handlebar nice feeling spike set new intake boot oiler works as well as adjuster screw new gaskets even gas tank. And the original piston I removed still had machining lines on it only had 3 owners an older gentleman who I think had it ran it here and there and sat it in the barn wasn't rusty at all no bearing play either came with a little stihl chain catcher. Second owner was the eBay seller had it just sitting around in his basement as a project that just sat and I basically fixed about everything put good money into getting good parts have ran the new 50mm so it should be a bit more broken in but probably could use more use I do have both styles of ignition currently have the points type in it but sent it in new mechanic and he stripped the holes in the flywheel bottom half and didn't install the pice properly so no spark. That's the only problem I have currently with this saw looking to trade for an 80cc chainsaw cause I need a saw that can actually pull 404 on a 32 inch bar
Sent from my SAMSUNG-SGH-I337 using Tapatalk
![32743fb82757a8da02b3357c7a24ae9e.jpg](/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20180706%2F32743fb82757a8da02b3357c7a24ae9e.jpg&hash=28a57b8359c49ec94874009df121dc9e)
