SteveSr
- 6:55 AM
- Dec 14, 2016
- North Carolina
Hello,
I have a later model 044 that is having a hard time oiling a (25) 24" bar buried in dry white oak. The saw is currently using about 1/2 tank of oil to tank of fuel WITH the oiler turned all the way up.
I just disassembled the oil pump and didn't really find any crud in the pump. I did, however, find some crusty stuff on the adjustment shaft and on the ramp area of the piston. I can't really tell if this crud limited the pump stroke or not. I have not had a chance to run the saw again since I had it apart.
So is this the expected performance of the oiler on the 044? If so, are there any modifications that I cam make to improve the oil output? I notice that the 460 pump is physically different on the pump output. After checking the 046 IPL I can't tell if the 046 piston or control bolt would fit in my 044 oil pump.
Thanks,
Steve
Thanks,
Steve
