Stihl 039 ms390 piston choice question?
idiotwithasaw
5:36 PM
Ky
I'm looking for some information on if anyone has ever tried to put a taller piston from another saw in an 039 ms390. This saw being a clamshell is almost impossible to set squish on without major machining. I was wondering if there was a piston available that had a taller pin to crown height, but the ring ends were still close enough to where they needed to be without hanging. I may be asking for a lot but it's a serious question.
And to let you know this saw will either have the band cut or a popup depending on how tall the piston is.
6:36 PM
What's your squish now with the OEM piston?
I've welded a dome as well, but that won't fix a loose squish.
6:36 PM
1 possibility is a stihl ts400 concrete saw. I heard it once but never looked into it. Same bore, stroke, rings, and open port, but I think it's 1mm taller
David Young
Safety First !!!!!!
6:36 PM
vt
I don't think it's that much taller. I remember stumpy did a swap. But the specs don't show it being taller.
idiotwithasaw
5:36 PM
Ky
What about a ts350 from pictures I've seen it appears to have a dome shape kind of like a homelite.
