tapritchett
Just got a mint 034, I want to swap out the piston and cylinder for a 036. Which aftermarket piston and cylinder is best? Part numbers?? I plan to do a bit of porting to the new jug.
OP better hurry up and buy that before I do just to stick on my shelf! I have a Super on the bench right now. I was working on the KS jug last night with the rotary motor I finally hung. The ceiling on the exhaust port on those jugs defy logic and the upper transfer port shape and corners are beautiful.Here's a good used OEM 036 top end that popped up the other day. Price is pretty good too
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/153890965769
I hear ya. I'd have bought it if I didn't have a couple on the shelf alreadyOP better hurry up and buy that before I do just to stick on my shelf! I have a Super on the bench right now. I was working on the KS jug last night with the rotary motor I finally hung. The ceiling on the exhaust port on those jugs defy logic and the upper transfer port shape and corners are beautiful.
@JohnnyBladeHere's a good used OEM 036 top end that popped up the other day. Price is pretty good too
WOW! Thanks for the tag Tim. I dont know how i missed this. Slacking i guess. Dang.
They're not that different. Take a few pictures and lay things on the bench together to help jog your memory. I seated a 48mm KS jug on a case last night. I have a few more parts to clean and should be assembling soon. Let me know if anything hangs you up or you want any pics.WOW! Thanks for the tag Tim. I dont know how i missed this. Slacking i guess. Dang.
Just stumbled on it looking for the link i posted in this thread. 034 is on deck! Parts coming in as we speak. Trying to research a lil more on the build. Besides ms250's and a few parts saws i had this is really my 2nd full stihl build. Out of my jred/husky comfort zone. Dont wanna pull a Munson
I haven't had to mess with the vents. This one is a super.Will do! So is ur 48mm KS an 034S or an 036 jug? Ill tell ya one thing rite now that is got me worried is the damn tank vent. Its the tower style that has 2 upright tubes, one tube has a set screw in it and one coarse thread flathead screw that goes through the top of both tubes.
this is the dude. U can see the set screw down in it. The tube with set screw is what goes directly on the tank. I cant get any air through it with the set screw in it. It shows it on the IPL so its supposed to be in there. Not sure how it works.I haven't had to mess with the vents. This one is a super.
Saw came in a box in pieces. So yes may have been having fuel issues JK i just like learning what makes these things tick. Yes its cost me money for sure but im learning instead of just getting them running. I just dont get how the set screw lets the tank breathe. The big screw at the top will let air in and out but the set screw is frogs azz tight. If u loosen it till it lets some air in or out i feel it could rattle out. I dont know if there is a factory setting for turns out or in on it but it would be nice to have a lil insight of how it operates. And yes i screwed it out and didnt count turnsMy vent is the same. I didn't pull it. Were you having fueling issues?
