Stihl 026
Bjorn
7:32 PM
Sweden
Hello. Is there a single ring piston available? for the the 026 44,7mm.
Wood Doctor
Edwin
9:32 PM
Omaha, Nebraska
I have done this for one Echo saw (500 EVL) and it worked. The saw runs fine today after five years, but I have never removed a ring from a Stihl chainsaw primarily because Stihl parts are more readily available. To my knowledge, there is no single-ring piston available for an 026.
10:32 PM
Why do you ask?
There is not. The 44mm can use a Husky 246 piston with some machine work.
Bjorn
7:32 PM
Sweden
Why do you ask?
The lower ring gap is close to the intake, trying to avoide ring snag.
10:32 PM
Yeah, and the lower ring is in the intake port at BDC. Gotta watch that and leave the PTO side roof factory to keep it well tucked.
I run them with a single ring all the time. As said above, just run top ring. No detriment at all.
Bjorn
7:32 PM
Sweden
Okey, thank you. I will only use the top ring, so I can wide the intake. This is only an expiriment, with farmertech cylinder. It will get a oem when I have find out some good porting numbers and shape.
NateSaw
10:32 PM
Maryland, USA
I'm running Doc's 44.7mm ported oem. Bottom ring deleted. It's fire! I imagine the piston is lighter than a single ring.
