brandonstclair20
- 1:39 PM
- Nov 21, 2016
- Starkville
I installed new nachi 6202 c3 bearings and new aftermarket crank seals. I installed new caber rings, a new carburetor and a new fuel line, and a new impulse line. When I was rebuilding the saw the bar studs were a little loose in the case, so I JB welded them in. I didn’t realize at the time that they were for 3003 mount bars. I went to fit a bar and I realized that, and my chains were too long. Also I’m not sure if the oiler hole would line up. I never did put gas in it. I didn’t go any further. Most likely you’d need to change the case. Cylinder and piston are in excellent shape. No scoring and piston still has most of the machining marks. $75 plus shipping. For an additional $10 I’ll include a MS210 engine housing.
