- 7:39 AM
- Aug 3, 2024
- Oregon
As I travel this new journey with chainsaws I've come to the conclusion that 1 of if not the most said statement is. I don't know? it ran fine before I let my buddy borrow it.
I think I might pick up a homeowners saw and label it for buddy if needed. Maybe I'll install a (break glass in case of emergency box) right next to where I store it. But instead of a fire extinguisher it will have oil seals and new rings.
I do have a question to add to this post for the saw gurus. Which saw would you recommend that is light weight,starts easy(by that I mean spring assisted starter) Preferably capable of running a 20 inch bar and something that is not to balls to the wall powerful. (The not to powerful part is my paranoia) Something that a disabled veteran can use. (His arms and legs are not what are disabled so a def leopard drumset isnt required)
he currently has a 80volt atlas which the weight and simplicity of starting it he likes but dislikes the battery. Any suggestions would be appreciated.
Husqvarna,Stihl and echo all have dealerships roughly the same distance from where we live just in different directions. So dealership distance isn't a issue
