toolmaker
- 3:16 PM
- Jan 31, 2020
- Tyrone, Pa
Modded MS460 25" Cannon Bar
I switched the 7 pin sprocket to an 8 pin sprocket
When I have the saw in a vise to file the chain, the chain gets "stuck" every few teeth/drivers, only when pulling the chain backwards.
If I have the file in a cutter and give it a little extra push to get through the tight spot, it goes right through and gets stuck again in a few more cutters away.
Could this be that the 8-pin is pushing the limits of teeth/drivers/sprocket diameter and the drivers are binding in a certain position?
