So what did you buy today
1:07 AM
I ordered a couple of these hand made in El Salvador condor knives
I have the larger low drag version and it's my favorite large knife
The sheath's alone from condor are excellent I've seen similar less quality sheath's sell for 40+ dollars.
jblnut
Flabs of Stihl
12:07 AM
Central Mn
Wondering, are these disc attachment nuts?
Yes they are. 30” blades with around 1,100lbs of downforce on each of them. Makes my 500hp tractor bark a bit.
Assuming the forklift / breaker bar combination is a known torque?;););)
“At least 3,000ft/lbs” Forklift will lift 6,000lbs so I should have “at least 3,000ft/lbs” with the lift point 2’ from the socket 😆
Partner
7:07 AM
Poland
A nice black Emak spool 12 years old and 2 Chinese ones. The orange one is new and the fuel lines have arrived / The chain is probably 0.404"
They call me Mr. Kibbs
1:07 AM
Wandering the VA woods
Yeah, I'd say that ought to do it! Big equipment for big open flat spaces, don't see a whole lot of either around here :risas3::risas3::risas3::risas3:
Appreciate the time taken to explain, different worlds!
heimannm
12:07 AM
Dike, Iowa
McCulloch 4 HP air cooled outboard motor. Same basic engine block as the 80cc chainsaws.
I also ordered a few small items (o-rings, spiral retaining rings, a few bolts) to get my Struck Magnatrac back in working order.
Mark
rogue60
3:07 PM
AU
Was sitting on the shelf in the shop covered in dust. I kind of felt sorry for it... Nobody wanted to take this beast home?.....
Seems all the homeowners buy 500i's or 3120's nowadays.. 🤔
I Can't remember the last time I've seen an air filter this clean? I feel the need too get it filthy asap! 😆
SimonHS
6:07 AM
Yorkshire, England
Partner
7:07 AM
Poland
7:07 AM
That welder looks good. Tiny form factor. Looks like it needs 20.8A at 230V input. Shame it doesn't have a 13A plug. You might need to be careful where you plug it in?
No worries, those 20Amps are peak.
Our outlets support 16Amps extended, and 10 or so Apms continuous.
I am sure it will work just fine if I can run my inverter 120Amp flux wire welder laying a continuous 4" long bead in multiple layers at max output (label says 17Amps max draw!).
