Scored a Ms 361 and a ms170 some issues
skelator
4:29 AM
Connecticut
Ok I know the 170 is like a throw away. It starts and runs but compression is really low and it smokes a lot. I see pistons and cylinders are way cheap so maybe I’ll give that a shot I’m not sure yet.
Now the reason for the deal the 361. It starts up on full choke and it idles at a normal speed if I leave it on full Choke. If I move it to half choke it revs to the moon then immediately dies. Any suggestions?
Woodwackr
2:29 AM
ID
Carb rebuild. If that don’t work, replace it.
Other than that…pull muffler and check piston. Do vac/pres test.
170s with a good muffler mod will cut like a 250.
hacskaroly
1:29 AM
Northern Idaho
Yes it is...but it was free so you can have some fun with it. For some real fun, the Milwaukee 7" bar does fit on the saw and I believe with a 31 driver chain (you may have to make it yourself if you have access to chain tools), but it would be a ripper!
As for the 361, possibly a dirty carb, need to clean it out and replace diaphragms if they are stale.
