Rim Spocket or Spur Sprocket
RI Chevy
1:48 PM
earth
Other than the obvious reasons of convertability of the Rim Sprocket, is there any cutting advantages/disadvantages of either clutch drum? One better than the other?
Clemsonfor
1:48 PM
Greenwood SC
Rim sprocket is much cheaper to replace when it wears out. The conversion is a few more pennies if your going from clutch drum spur to rim if your talking changing one.
RI Chevy
1:48 PM
earth
Thank you sir. I should have clarified better. I am interested in the performance differences between rim and spur.
RI Chevy
1:48 PM
earth
True. I have noticed that the spur sprockets do wear out faster.
How about cutability?
RI Chevy
1:48 PM
earth
OK. That's kinda what I thought. Thanks. [emoji106]
jackjcc
12:48 PM
Minnesota
I’ve converted everything I’ve owned to rim. Y work saws are sprocket and I feel like I put in WO’s to change them twice as often as the other crews.
Philbert
Chainsaw Enthusiast
12:48 PM
East Dakota
Once the chain is mounted, I am not aware of any advantages.
Rim sprockets are supposed to 'self-align' the chains when cutting; whereas spur sprockets develop a wear groove.
Spur sprockets are more likely to burr drive links when a chain jumps the bar groove.
Chains are slightly easier to mount on spur sprockets.
Spur sprockets are often used with small pitch chains, due to size issues.
If I had a saw with a spur sprocket, I would not replace it with a rim sprocket until it wore out, or developed other problems.
Philbert
Homemade
1:48 PM
Wisconsin
Once the chain is mounted, i am not aware of any advantages.
Philbert
Once again philbert, accurate description. Nice job.
jakethesnake
I Am The Snake
1:48 PM
Here & Now
I’ll run either. However I prefer rims. I like to swap chains from one saw to another fairly often. If running a spur sprocket the chain drivers do get dinged up. It doesn’t bother me that much however it does bug me a little. Sorta hate putting a dinged up loop on a nice new rim sprocket. I haven’t noticed any abnormal wear on my rims due to putting a dinged chain on them though. Meh. If replacing stuff and price is similar I convert all of em to rim drive
1:48 PM
NW CT
Philbert
I concur with this. I believe the rim is better, in regards to wear, than sprocket for the chain. Being able to “float” simplifies proper alignment and reduces the chance of a groove for the chain to sit in. Once the chain eats a groove in a spur, any new chains or chain/bar will be forced to ride in the previous groove which can lead to uneven wear. The rim is also “smoother” running because it dissipates more of the chain/drive vibration.
In regards to power, I truly believe a spur will make more power. Less parasitic loss with the spur because less moving parts. The rim will have more loss not just because of more parts but the rim also “rattles” on the rim sprocket. Its not a tight fit and allows vertical/lateral movement which is also parasitic loss.
That’s just my opinionated opinion
kingOFgEEEks
1:48 PM
Tioga County, PA
I converted an MS310 once, and the rim setup felt like it produced a little less vibration in the cut. Probably not enough to make any measurable difference, though.
CR888
5:48 AM
Australia
Why do $1000+ top handle pro saws come with spur sprockets? Why do pole saws all have spur sprockets? Does a spur assist in removal of chips & prevent/prolong clogging of clutch cover? I'll take a rim setup on near all occaisions mainly due to cost and the fact a clutch drum usually takes 4+ sprockets before it needs replacing so its sensible to replace the worn part instead of drum and sprocket together which you have to do with a spur welded to a drum. But on pole saws its usually a spur by itself and a rim 'could' be used like in the design of a log wizard where they use a rim to drive the rotor. So why do OEM's by many brands choose spurs in pole saws and top handles? Just a few Q's to think about ;)
12:48 PM
Most of them saws are a 6 tooth set up and so for space reasons a spur has to be used to get that small.
RocketRoss57
Taco Bell Aficionado
10:48 AM
Willamette Valley
I was told by an Oregon rep the other day that some people believe that the Spurs clean out better when cutting in very dirty conditions. He said that they have a client somewhere that they cut extremely dirty wood and have swapped all their saws to spur along with hard nose bars and some series of chain that they make that has a thicker layer of chrome on the cutters. Cant remember where but if memory serves its timber that is underwater during flood seasons.
