Removing tach from boat
merc_man
merc_man
1:30 AM
southern ontario
The tack in the boat quit working years ago and i wanted to figure out what was going on but cant figure out how to get tach out.
Ther is a small opening under helm where battery goes about big enough to stick you head in.
Any ideas how to remove the tach?
Heres a few pics.
Boats a 07 smokercraft powered by of coarse mercury hence my user name lol.
redline4
I'm huge in Japan
12:30 AM
Rosholt Wisconsin
By just looking at pics, my guess would be some hidden screws underneath that hold the silver guage bezels to the dash.
I dont own a boat, so its just speculation!
MarkEagleUSA
1:30 AM
CT
Is there access from under the dash?
merc_man
merc_man
1:30 AM
southern ontario
There is a screw at the pointy part of the silver thing but mabe only have an in clearance from windshield. Was thinking that had to come off. Not sure.
merc_man
merc_man
1:30 AM
southern ontario
Every marine gauge i have ever seen is held in place by a U shaped bracket with 2 nuts with 2 studs on the back of the gauge.
I can see that from underneith but tjere aint much room under ther. Barley get my head under and a hand with the flashlight. May try it though. I was wondering if that was how.
Mabe i could send my little girl under there. She is pretty flexible lol
merc_man
merc_man
1:30 AM
southern ontario
That little access hole is little wider and little taller then the marine battery is. But im starting to think thats the only way to get it out.
Ther is also a conextor hanging down under ther but i couldnt see where it went. Im pretty sure all the guages have a harness in them. Will try to get time maybe tomorrow after work to have a look at it.
smoker
1:30 AM
Sawlogbay Ontario
That's how mine was mounted...small wrench to loosen the two nuts...then loosen the rest with fingers..
Does the backlight come on?...it powers the meter....the signal come from the alternator and not the ignition (OMC).
On OMC the regulator had a defective diode that cause the meter to quit. I wasted lots of time removing and testing the
tach...replacing the regulator solved the problem
The tach definitely pulls out from the front .
merc_man
merc_man
1:30 AM
southern ontario
Im not sure if the light comes on or not. I will check tomorrow when i get the battery back in. I gonna do sone looking on net to see if i can find the wire color for the signal wire on the motor side.
Larry B
1:30 AM
SW ohio
The console was probably assembled, prewired then set in place. Look to see if there is a connectorbetween the boat wiring and the console. Good blace for meter test points.
merc_man
merc_man
1:30 AM
southern ontario
I found on line the tach signal wire on motor side is gray. Gonna start ther so long as i have power at the tach.
AlfA01
8:30 AM
Evia, Greece
Any luck? You may have to remove your switch panel to get access to the tach. You will probably want to check all the wire connections there anyways.
Good luck!
exp500
1:30 AM
usa
How about removing the eyebrow panel with an "S" above tach? Might give you a big hole.
Stevetheboatguy
12:30 AM
Nw IL
This /\/\/\/\/\/\
If you need any help drop me a pm or @WillG
Steven
Bilge Rat
1:30 AM
savannah georgia
Usually 2 nuts holding a strip of metal holding the gauges in.
Nuts are about 1/4"
Freshwater boats and pleasure boats have all the padding, frills that get in the way.
Saltwater fishing boats that i piddle with are just fiberglass with hatches or some form of access.
Just installed a new Yamaha tach in my boat.
It took longer to find the right socket for the nuts and properly replace ty-wraps than to R and R the tach.
Don't forget to spray a little corrosion prevent on the contacts in the plug and on the ends of the inline fuse if one is used.
Ty-wraps and orderly wire routing is your friend.
Biggest issue in boats is the idiots that wire them then idiots that attempt to work on the wiring with wire nuts and tape.
Bare splices in the bilge Splices into any old hot wire etc.
We see more issues with bad grounds than with bad hots in a salt envirnoment.
The ground wire will be green inside with very little corrosion on the ends.
Boats are so much fun!
