Philbert
Chainsaw Enthusiast
- 10:14 AM
- Jan 30, 2016
- East Dakota
Came across a ratcheting chainsaw tool, designed to tighten and remove bar nuts with the ease of a socket wrench, and the convenience of a conventional scrench: the 'RatchetScrench'
https://ratchetscrench.com/
First Impressions
Got mine the other day: under $24 shipped, when buying direct or from Amazon.
Feels like a decent quality tool. Overall appearance is pretty good, with a textured, chrome finish. Some minor, cosmetic issues on mine: one side of the screwdriver has a small 'step' in it; the ratchet lever is rounded over on one side, but sharper on the other side; and the rivet feels a little light. But it feels like it should hold up, unless used to pry open crates, or if packed with sand.
I took it over to my STIHL dealer and it worked on every saw I tried, including a few Husqvarnas (except for the saws with tool-less chain tensioners - those sides were facing towards the slat wall, and I had to turn each one around to see!). I also learned that some STIHL saws use the 13mm bar nuts!
It really seemed to be of value with saws that have full wrap handles: the ratchet mechanism eliminates the need to reposition the scrench when there is limited access. My dealer, a fourth generation saw shop, even seemed interested.
I also tried it with a few different types of gloves that I wear when operating a chainsaw: mostly 'mechanic's-style' gloves, but also some heavier leather ones. The lever was easy to operate and responded with a distinct 'click'.
Philbert
First Impressions
Philbert
