Vancouver timber
Just acquired this saw it was an old loggers saw who didn’t even use a power saw anymore just ran processor. This one sat is his crumby (work truck) and was barely ever used gas had turned and the saw wouldn’t run. I purchased the saw did the entire fuel system carb tested the line new fuel filter new air filter pressure / vac tested saw. Piston still has all the factory cross hatching on the exhaust and intake saw hasn’t been rebuilt it’s all oem minus what appear to be pipe nipples welded into the oem casing. Can put a stock casing on if preferred it does however look awesome the whole saw looks great it sounds great no hidden problems here all maintenance is up to date. Not even sure what to value this saw at but I have a 18” Stihl pro bar or 28” Stihl pro bar both in great shape for the buyer to choose from or can do PHO.
